    https://www.rapidonline.com/single-primary
    Are you sure they only sell a 500VA one?
    Edit: oh I see. You're saying only one that has two 45V secondaries.
    In that case you just have to play around with the secondary voltage, e.g. using 2x25V in series, or go to a different supplier.
  2. The Following User Says Thank You to AndyUK For This Useful Post:
  3. #2
    Hmmm, the more I think about it the solution seems to be to wire the two 45V outputs from the 500VA tranny in parallel thereby doubling the output amperage to 12A.
  1. Mach 3 jogging query
    By Stressedwoodman in forum Artsoft Mach (3 & 4)
    Last Post: 29-12-2018, 05:58 PM
  2. BF support bearing query
    By Voicecoil in forum Lead Screws, Nuts & Supports
    Last Post: 16-12-2018, 12:32 PM
  3. NEW MEMBER: Query:
    By Rwright in forum New Member Introductions
    Last Post: 29-01-2018, 11:05 AM
  4. CNC newbie electronics query II
    By Skydeals in forum General Electronics
    Last Post: 09-07-2014, 10:33 PM
  5. CNC newbie electronics query
    Last Post: 08-07-2014, 06:06 AM
