Thread: DIY PSU build query...
29-02-2020 #15
Are you sure you about the serial or do you mean parallel ?
I think you need to re visit this as I don't think you understand it. It is also misleading for others.The bridge rectifier drops the voltage, it converts AC to DC you connect both outputs in series run it through the rectifier and 72v out the other side in DC.
You need capacitors to clean up the DC.
Doddy is correct...Clive
Mach 3 jogging query
By Stressedwoodman in forum Artsoft Mach (3 & 4)Replies: 6Last Post: 29-12-2018, 05:58 PM -
BF support bearing query
By Voicecoil in forum Lead Screws, Nuts & SupportsReplies: 2Last Post: 16-12-2018, 12:32 PM -
NEW MEMBER: Query:
By Rwright in forum New Member IntroductionsReplies: 0Last Post: 29-01-2018, 11:05 AM -
CNC newbie electronics query II
By Skydeals in forum General ElectronicsReplies: 4Last Post: 09-07-2014, 10:33 PM -
By Skydeals in forum General ElectronicsReplies: 17Last Post: 08-07-2014, 06:06 AM
