Thread: Xsy-at1 error 6 over current
Error 6 is for over current. I get the error when I put the motor under load. So when I am grinding hard on something at a higher speed.
Thanks routercnc I'll give it a watch.
20-02-2020 #2
Also change P062 to 3 which will show current draw in Amps on the display (instead of motor frequency). This may give you a clue as to what is going on.
On the accel/decel suggestion - my unit was shipped with very low accel and decel rates by default (50 Hz / s) so the current draw should be low when changing speed, although this depends on the inertia of the grinding disc (and motor armature). To test this out you can make this even slower in P034 & P042 (accel / decel) and set it to 25 or 10 Hz / s in case that sorts it out, then go up from there.
If not double check the parameters above for your motor settings . . . .
Help please - Leadshine EM806 over-current error
By Noplace in forum Motor Drivers & ControllersReplies: 3Last Post: 25-08-2015, 04:02 PM -
not enough current for relays?
By Boyan Silyavski in forum General ElectronicsReplies: 17Last Post: 17-08-2015, 10:05 AM -
VFD error
By routercnc in forum Spindles & Drive MotorsReplies: 37Last Post: 21-06-2014, 08:40 PM -
Current Set Resistors.
By NzOldun in forum Motor Drivers & ControllersReplies: 1Last Post: 20-06-2011, 08:38 AM -
G540 Current set resistors
By blueseidboy in forum Motor Drivers & ControllersReplies: 3Last Post: 23-08-2010, 02:21 PM
