23-07-2020 #6
Thank you for explanation, that solve my same problem, with a little plc 20khz output frequency.
Your suggestion are perfetc, now the motor (BLDC,1kw, max 2500 rpm) run perfectly.
Only one question, if there are particular setup to fix for correct rotation, CW and CCW, because now, with your setup and same pulse generator, the motor run only in CW direction.. From the manual, very bad, seem not be particular setup are requestd for the rotation, in both direction.
The 2.2Kw Chinese Spindles - Info, Setup and Advice + More
By Husky in forum Generic Chinese SpindlesReplies: 222Last Post: 22-01-2021, 06:54 PM -
Servo Manuals - Chinese Sellers
By Chaz in forum General ElectronicsReplies: 1Last Post: 30-04-2019, 12:12 PM -
Need a bit of help with servo settings/setup
By alboy in forum General DiscussionReplies: 1Last Post: 07-06-2018, 11:04 AM -
Rack & Pinion Gearbox/Gearing
By andrewbond in forum Rack & Pinion SystemsReplies: 21Last Post: 12-09-2015, 09:10 AM -
motor gearing (cog) help please
By martin54 in forum Linear & Rotary MotionReplies: 5Last Post: 06-07-2013, 11:48 PM
