    So, looks like I'm going to need some cutting bits in the near future, and as my previous machine used PCB type endmills, its time to get serious.
    Can people recommend a starter collection for playing around in wood? So far I'm thinking:
    • 10mm or 1/2" long straight two flute router bit for hogging material.
    • 90 Degree V-groove bit
    • 60 Degree V-groove bit
    • Ball Nose Endmill - Around 5 or 6mm?
    • Compression Bit - Around 5/6mm?
    Can anyone flesh out details on that list I should be thinking about.
    Anything else that I should consider essential?
    What materials should I go for? Is Carbide too much?
    Where should I go? Any bay of fleas / Aliexpress recommendations? Any decent UK suppliers?
    phill05's Avatar
    Lives in Derbyshire  UK, United Kingdom. Last Activity: 10 Hours Ago Has a total post count of 301. Received thanks 28 times, giving thanks to others 13 times.
    Everything you might need: https://www.shop-apt.co.uk
    Quote Originally Posted by phill05 View Post
    +1 ......and they give some guidance on speeds & feeds on a lot of their cutters, which I've found useful.
    Just a note. I have recently had some very poor quality cutters from apt. Vibrating even when slowing rpm right down. Most cutters from them have een good though
    Quote Originally Posted by johngoodrich View Post
    May I ask what shape & size the bad ones were please?
    phill05's Avatar
    I have been using from micro size up to 12mm for a number of years and cannot remember having any problems other than my own fault braking cutters
    It was on 3 flute 45 degree 12mm aluminium cutter. All other sizes were fine. Maybe just a bad batch ground up. They replaced them once I told them the issue so can't fault their service at all and the pricing is great
    Thanks for the suggestions - just ordered a selection to get me started.
  9. Maybe you can try ARDEN V Groove Router Bits later, ARDEN is a famous brand with reliable quality.
  1. Tool run out - Video
    By Dangle_kt in forum Tool & Tooling Technology
    Last Post: 18-01-2017, 04:44 PM
  2. Tool Pre-setter
    By Leadhead in forum Tool & Tooling Technology
    Last Post: 28-09-2013, 10:56 AM
  3. Looking for a tool ( oohharrr )
    By Fivetide in forum Tool & Tooling Technology
    Last Post: 24-07-2013, 10:28 PM
  4. round over tool for Alu.
    By jcb121 in forum Tool & Tooling Technology
    Last Post: 19-07-2013, 12:14 AM
  5. What tool would you use for this?
    By Kai in forum Tool & Tooling Technology
    Last Post: 21-03-2011, 06:08 PM
