    Hi, probably a dumb question but I have a set of Ballnose mills for 3d carving.
    One has R0.75 printed on it and another one has R2 what does this mean? I assume radius and how do I program this into my tool on Fusion 360?
    How do I set this up?
Name:	Ballnose tool 1.png
    yes the R is for radius so the r2 will be diameter of 4mm etc. To set it up in fusion, got to the ,manufacture tab, and the click on manage at the top right of the screen. In the drop down menu select tool library. I personally keep all my tools under the "local" folder so click on local and then mills. in top right click on new mill tool, leftmost of the five icons there and under the cutter tab you can select the type of tool, ballnose being one of them, and input the diameter and length parameters of your tool
  4. The Following User Says Thank You to johngoodrich For This Useful Post:
  5. #4
    Quote Originally Posted by johngoodrich View Post
    Of course, lol so set it up as a 1.5mm damn I was having a blonde moment there.
    I am a natural blonde so I can be excused ;)
  6. #5
    That worked perfectly thanks machine is finally doing exactly what I want it to.
  7. #6
    No probs
  1. Carbide taper ball nose cutters
    By Leadhead in forum Tool & Tooling Technology
    Last Post: 08-01-2020, 06:45 AM
  2. 1mm Ball Nose Bit Advice
    By dcrowder in forum Tool & Tooling Technology
    Last Post: 18-04-2016, 06:15 PM
  3. WANTED: 3mm Ball nose bit please
    By Fivetide in forum Items Wanted
    Last Post: 12-12-2012, 05:06 PM
  4. Where to buy long ball nose mill for foam cutting?
    By jamezwarner in forum Marketplace Discussion
    Last Post: 10-05-2012, 02:03 PM
  5. FOR SALE: End mills and Ball mills for sale......
    Last Post: 16-02-2011, 12:37 AM
