Thread: A very streamlined CNC design...
04-03-2020 #9
Ok well, first of all, 10mm is not heavy plate, it's not even thick plate and to be honest, it doesn't add anything to the machine but excess weight in the one place you don't want it. Also, 80Kg isn't heavy for a strong machine this size.!
However, I wasn't referring to the gantry sides but rather all the tin sheet that covers the gantry and screws, etc. Looking at the gantry in the video they don't offer much in way of chip protection and actually look like chip traps so why cover it.? . . . I'll tell you why I think it's covered.! . . . .To make it look better than it really is. They don't want you to see that the gantry is actually quite flimsy built using a single narrow piece of aluminum profile.! I'm also guessing the same goes for long axis and what's hiding behind those covers.!
I've worked on many machines built in the same way. Both Denford and Boxford Routers use this method of hiding weak structures behind tin covers designed to make them look more industrial than they really are. Strip the covers off and they look like chickens without feathers.!
My point in saying all this to highlight that just because it's a Felder or German doesn't automatically mean it's quality or strong. No more than looking BLING will make it cut good.!
Interesting Papers on heavy duty design, vibrations, composites and column design
By D.C. in forum Gantry/Router Machines & BuildingReplies: 15Last Post: 25-06-2016, 10:13 PM -
Design Help Pt2 Required for CNC design/Build
By MikeyC38 in forum Gantry/Router Machines & BuildingReplies: 38Last Post: 21-07-2014, 02:05 PM -
RFQ: Pre-RFQ Design
By Hutchie in forum Projects, Jobs & RequestsReplies: 11Last Post: 05-02-2012, 06:45 PM -
