Thread: Joe90's BIG RAT Build.
	29-06-2020 #1Personally I use 20mm mostly but 15mm would work for a lighter Z-axis. Just remember the Z-axis is handling all the cutting forces so if it vibrates then the tool vibrates with it and you get a shitty finish, excess tool wear and even breakages if bad.! . . . Some areas you don't want to skimp on and Z-axis is #1. -use common sense, if you lack it, there is no software to help that.
 Email: [email protected]
 Web site: www.jazzcnc.co.uk
	21-07-2020 #2Deleted due to errors. Last edited by joe.ninety; 21-07-2020 at 06:37 PM.
  BUILD LOG: New Build - For Your Amusement - MK-2 buildBy Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
