Page 2 of 2 FirstFirst 12
    Got it.
    Thank you - everything is so easy when you can see the cct diagram.
    Many thanks for the doc.
    Indeed it's a continuity type so all is working.
    The manual doesn't cover how to centre the probe.
    I have about 0.07mm offset.
    What's the method for correcting ?
    Page 6 suggests that there is no intended adjustment, but that does not mean that it's not possible (check for runout on the arbour first, just in case).
    The adjustment if any, is probably internal and used during assembly.
    Muzzer's Avatar
    Lives in Lytham St. Annes, United Kingdom. Last Activity: 2 Hours Ago Has been a member for 7-8 years. Has a total post count of 461. Received thanks 73 times, giving thanks to others 20 times.
    Seems to use the workpiece and machine to complete an electric circuit on contact, so be aware that it won't work on plastics, wood etc. Should be decent quality though!
  5. #15
    It is indeed built very well, much more sturdy than my existing one.
    Yes, it's only usable on conductive materials.
    I'll have to check the run-out on the collet to find whats contributing to my error.
  6. #16
    Just had time to have a close look at my probe.
    The top plate (that has the arbour attached), is fixed to the main body by 3 screws.
    With these 3 screws loosened off, just enough to allow movement, but not "rattling loose", the main body can be adjusted independently of the top plate and arbour, until the probe tip clocks true, then re tighten the screws.
  7. #17
    i saw the 3 screws
    there is a set top and bottom
    and the body seems to be 3 sections pancaked together
    but mine seems to have got it self very much stuck together.
  8. #18
    As this is an old thread this is a long shot. I have acquired a Mitutoyo 902329 probe in first class condition.
    Nick952 kindly scanned and uploaded the manual but the link reveals the file has been deleted. If Nick952 or
    anyone reading this has a copy of the manual, I would much appreciate a copy.
  9. #19
    Muzzer's Avatar
    I think I saw this on HW website yesterday(?).
    Be aware (as noted previously) that this relies on conduction to the workpiece. Also, the overtravel seems rather limited.
    Like you, I couldn't see a manual out there beyond an old brochure - page 31 https://www.yumpu.com/en/document/re...ca-corporation
  10. #20
    Quote Originally Posted by Muzzer View Post
    Thanks for the brochure link. I now have the probe wired in as a conductance probe for edge finding which suits my purpose.
  1. Need help with % probe
    By Sp00kie13 in forum General Discussion
    Last Post: 11-10-2018, 03:45 PM
  2. Edge Probe + tool length probe on same input
    By Noplace in forum General Electronics
    Last Post: 18-06-2016, 11:12 AM
  3. CNC Probe - Tried this one?
    By Davek0974 in forum Machine Discussion
    Last Post: 03-06-2016, 02:58 PM
  4. eBay: Quillstar/Mitutoyo DRO for turret mill
    By steve400 in forum Items On eBay UK
    Last Post: 02-05-2016, 03:24 PM
  5. FOR SALE: BEVEL PROTRACTOR (Mitutoyo Series 187) 300mm
    By benbenrf in forum Items For Sale
    Last Post: 16-07-2009, 04:33 PM
