29-02-2020 #2
I'm not the most experienced here with touchplates, but sounds like the probe connection is screwy.
Do you have the touch plate type with a switch in or is it just closing the circuit on contact?
If its the switch type, the behavior you're describing would tally with the switch not activating in some cases (the machine keeps going down until it sees the switch close), or not releasing in other cases (the machine is supposed to hit the switch, then back off until the switch opens again - but never sees the switch open again so carries on up).
Might also apply to the closed circuit on contact - but either way I'd be looking at my zero plate and it's wiring rather than the Z motor.
CONVERSION: Bridgeport Manual to CNC conversion...
By Davek0974 in forum Conversion Build LogsReplies: 413Last Post: 05-04-2020, 08:07 PM -
CNC is unresponsive to x y z movenment manually
By eugeleb in forum Control Hardware & SystemsReplies: 0Last Post: 29-02-2020, 02:35 AM -
Manual lube oil
By alboy in forum General DiscussionReplies: 3Last Post: 22-07-2016, 11:02 PM -
WANTED: Centec 2A manual
By Web Goblin in forum Items WantedReplies: 0Last Post: 03-09-2012, 09:56 AM -
Translating the manual
By Robin Hewitt in forum Moulding MachinesReplies: 22Last Post: 01-09-2012, 01:21 PM
