Quote Originally Posted by pippin88 View Post
Add a second spindle bracket up high on the spindle.
According to the spindle specification, the clamping area is defined here:
Name:	Spindle clamping range.PNG
I am afraid that clamping higher up (I am at the highest allowed point already) could potentially damage the spindle. Please correct me if I am wrong? The reason why the spindle is clamped like this is for gantry clearance.
Add ribs on the edge of the Z axis plates. This will add a huge amount to stiffness. (Essentially make them into C channels).
Nowhere on the machine should you have a simple flat plate - everything should be box sections of at all possible, otherwise should have stiffening ribs.
Good point! While I am trying to keep the Z-axis weight low, I think adding 15mm aluminium stiffening ribs wouldn't be too harmful (only around 1.2kg added). If I understood you correctly, you means something similar to this:
Name:	Z-axis with stiffening ribs.PNG
ID:	27512 Click image for larger version.
Name:	Z-axis with stiffenings ribs.PNG
ID:	27513 Click image for larger version.
Name:	Z-axis moving weigth with stiffening ribs.PNG
Additionally I could also move the Z-axis linear rail spacers to the front plate. This would increase the moving weight by another 1kg. I am not sure fi I should keep them on the rear plate or not. I could move them to the front plate and add stiffening ribs to the back of the rear plate. The ribs would be bolted to the rear plate, top bearing plate and motor bracket, effectively forming a rigid box. Is this just adding dead weight?
Name:	Move Z-axis spacer plates and add bracing.PNG
