Thread: NordicCNC's build log
05-03-2020 #9
Regarding spindle, I didn't realise it was an ATC spindle, which are a lot longer. Clamping high up may not be appropriate (though with a decent tolerance clamp I doubt you'd be crushing the spindle). The point is the longer the clamping area (or the further apart the clamping points) the better.
Yes, that's what I meant about the ribs. You don't need 15mm thick plate, even 5mm would be fine. The stiffness comes from the dimension in the direction of the force.
You should also add stiffening ribs to the carriage .
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
