Thread: NordicCNC's build log
13-03-2020 #10
You can have 20mtr/min speeds with steppers if you choose the right drives/motors along with linear components, the 10x5 vertical machine I've been showing will happily whizz the gantry around at 30mtr/min.
Yes, those are exactly what I'm using for Z-axis with 12Nm on X&Y. I think the heading is an error, if you look further down at the spec you'll see it says 8Nm.
This size would be way overkill for your little machine thou. The secret to the speed with steppers, in general, is the relationship between inductance and voltage, but even more so with large motors which is why Mains powered drives work best.
It's Got nothing to do with quality, that's down to manufacturer and spec. HTD, GT2, etc is the tooth profile. GT2 is actually a modified HTD tooth profile which supposedly offers better handling of torque and speed than HTD.Last edited by JAZZCNC; 13-03-2020 at 05:59 PM.
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
