Home & limit switches
Z-axis home switch at the top end of the travel. Soft limit will be used for the lower end of the travel.
Name:	Z-axis home switch.PNG
X-axis home switch & limit switch on the moving part. Adjustable bolts in the t-slot in the lower right and upper left of the picture. The lower right will be used for home & limit switch and the upper left will be used for limit switch.
Name:	X-axis home switch and limit switch.PNG
Y-axis home and limit switch on the moving part. Adjustable bolts in the t-slot on the left side of the base frame. Upper left one is used for limit switch and lower right one is used for home & limit switch. On the opposite side (right side) is the second home switch. The purpose with 2 home switches is to be auto to auto square the gantry when homing the axis.
Name:	Y-axis home switch and limit switch left side.PNG
ID:	27669 Click image for larger version.
Name:	Y-axis home switch right side.PNG
Alternatively I could have all the proximity sensors fixed and not on the moving parts. Then I could use soft limits for all axis's in the opposite end of the homing position, same way as with the Z-axis. Would that be a bad idea? It would be less cable routing of the sensors in the cable drag chains,
