Thread: NordicCNC's build log
17-04-2020 #11
So machine design is now what I consider 99% completed so that I can start ordering parts. Since none replied on the ballscrew change I've decided to do the following:
- Keep the 2:1 ratio
- Change Y- and X-axis ballscrews to 2020
- Keep the Z-axis ballscrews as 1605
- No belt tensioners
- Double Y-axis motors will be used
I will put together a shopping list for all components so that I can get as much as possible in one order without missing anything. The final piece of design was to find a good location for the Y-axis home/limit switch. Cable chains I will fit later and wont add those to the 3D at all. Please ignore that the screw is not in the center of the limit switch. I will lathe and mill some custom screws but I could not care to design those yet.
Final assembly!
Some things still bugging me is the 120x80 for the gantry. I hope that those will not be too weak for machining aluminium with the ATC spindle. I am still consider changing to 160x80. JAZZ, if you read this, I remember that you wrote somewhere that for larger machines you use the 160x80 for the L-shape gantry. Since my gantry is 1200mm wide and I am using an ATC spindle, would it be wise to go for 160x80 anyway?
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
