Thread: NordicCNC's build log
Hi Andy! Thanks for pointing this out. I will update the starting post with what my definition of good means. With good I mean that after my finishing pass, I want a smooth surface on which you should not/rarely be able to see vibration marks if you don't look extremely closely. The tolerances that you can achieve with a machine also very much depends on the machine operator. You cannot expect to get a good tolerance with roughing passes, even with industrial machines without using some tool compensation or adjusting the G-codes.
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
