Thread: NordicCNC's build log
13-03-2020 #11
Step/Dir is the most reliable and flexible. With analog +10V you're forced to control the servo in velocity mode.
With Step/Dir you can control it in position or velocity mode.
I'm also convinced position mode (letting the drive close all the loops internally) is the best way since the drive can do it much faster than the controller.
The interface of the servo drive is a whole other topic and has nothing to do with absolute encoders. For absolute encoders you need to connect a battery and 2 extra wires to request the position data when using the standard analog/pulse-train drives. And as I said above, the controller needs to be able to read the position data for the specific servo manufacturer.
Now if you use EtherCAT drives, indeed you just need a RJ-45 cable between the drive and controller (but still need the battery). But you have 2 more problems:
- you need to actually find one of those rare EtherCat drives. Yaskawa for example doesn't sell them in the Chinese market. So you would need to go through an official reseller and pay $$$, or buy another brand: Omron / Panasonic / Mitsubishi / Delta / Estun...
- be prepared to spend weeks and write some C to make the controller talk to the drive (LinuxCNC in this case, the only one supporting EtherCAT).
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
