You don't need or want 6 counterbored holes in the lower gantry just use the 3 furthest away from the gantry side and the center front one, you can miss the out the center bolt through the gantry side or put it in but with short threads. Reason being the bolts going through gantry side clash with bolts and it's more important you get good fastening into sides so longer bolts needed. Between them, the gantry is going now were trust me.!
Good notice! I have corrected that now and I will use shorter threaded bolts for the center ones (red arrow).
Name:	Gantry bolts.PNG
ID:	27604 Click image for larger version.
Name:	Gantry bolts 1.PNG
Also with the ball screw spacer plates pay careful attention to fastening bolts and that you can actually access them with BK bearing and screw in place because you'll need to adjust these on the machine when setting alignment etc.
Yes, I should be able to access those at anytime with current design.
ID:	27606 Click image for larger version.
Name:	X-axis float.PNG
I have also replaced the guide carriages with the wider version, as you suggested.
Name:	X-axis wide carriages.PNG
ID:	27608 Click image for larger version.
Name:	X-axis wide carriages 1.PNG
Thanks for your feedback, I appreciate it!
