Thread: NordicCNC's build log
17-03-2020 #9
Those are some extremely good points..
By moving the motors to the outside of 160x80 profiles, the belt lengths will be shorter and I will be able to move the 80x80 profiles down 80mm. This in turn will decrease the needed height of my gantry sides by 80mm while also protecting the Y-axis rails.
There is no doubt, I will make those changes. Maybe I could even change the sides to 200x80 and be able to make the gantry sides even lower! Now it starts to turn into a raised gantry design. The drawback will be that it becomes more difficult so access the machine table from the side, when e.g. fastening the workpiece.
Thanks JAZZ!
Skickat från min SM-A530F via Tapatalk
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
