Thread: NordicCNC's build log
19-05-2020 #19
No they will be correct, they are twin start screws. If you look carefully at the end you will see multiple threads, but it's easy to check just rotate the ballnut and measure how far it moves.
It's a common mistake.
The reason they use this method is it gives higher torque and lessens the depth required and keeps the screw stronger.-use common sense, if you lack it, there is no software to help that.
Email: [email protected]
Web site: www.jazzcnc.co.uk
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
