Thread: NordicCNC's build log
22-05-2020 #25
Sorry, the pitch was of course correct! Thanks for having me double check, I dont think I've realized unless until the build was finished!
About building the enclosure into lower frame with aluminium plates is a good idea. I have a large 2mm aluminium sheet lying around that I could use. For the next step I will lay out the electrical components in 3D and make a wiring diagram to ensure I have accounted for everything.
I've seen that atleast both DMM and Sunfar recommends either mains filter or both mains filter and line reactor for the mains power supply. I have seen people here using line filters but I haven't come across anyone using line reactors yet. Is that really as necessary as the manufacturers are claiming it to be?
Also mounting the electrical enclosure directly to the frame (made of aluminium) would it be a problem since it would basically be in direct contact with the machine frame? I mean that would be a direct earth connection for the enclosure. I am not too into electronics (yet)!
Thanks everyone for your good and helpful advice!
Skickat från min SM-A530F via Tapatalk
By Karl in forum DIY Router Build LogsReplies: 12Last Post: 08-02-2017, 08:03 PM
