Thread: stepper speed very slow
23-10-2009 #1
hi
what speed can i expect from a wood router running 3nm nema 23 steppers on 3 axis, using the diycnc sytem 3+ board, 2 amp per phase
24 volt power supply , i can only get about 80mm per min in mach 3 painfully slow
23-10-2009 #2
:feedback:
More info needed.
What screws and pitch, what microstepping selected ?
.John S -
23-10-2009 #3Visit Us: www.automationshop.co.uk
23-10-2009 #4
hi
1/8 step, 3mm pitch one start trapezioid screw, direct drive
24-10-2009 #5Visit Us: www.automationshop.co.uk
24-10-2009 #6
hi
just got the router going have a pen fixed to the z so just drawing with g code , as the z axis travels along the steppers pitch ( as in sound) gets higher every two or three secondsLast edited by jonm; 24-10-2009 at 01:00 AM.
24-10-2009 #7
That sounds like acceleration could be way way way too low - if the pitch gets higher every so often, then it's probably ramping up.
24-10-2009 #8
I would expect those steppers, even on 24v, to handle 2000 full steps/sec easily, thats 10rps, 600rpm or 1800mm/min with little load...
80mm/min = 26rpm = 0.43rps, 86 full steps/sec
have you told MACH3 you are using 1/8 step?
It does suggest your MACH3 settings are wrong...
24-10-2009 #9
24-10-2009 #10
hi irving
i have the "steps per " in mach set to 533.3
200 X 8 = 1600 divided by the screw pitch which is 3mm = 533.3
maybe i am missing something here
resolution seems good i drew a 300mm diam circle and measured it to exactly 300mm
but the speed is very slow
Need to slow down a signal due to Safe Torque Off alarm
By corkcnc in forum General ElectronicsReplies: 0Last Post: 04-06-2014, 11:35 PM -
Machine Slow on Curves
By swisscheese in forum Computer SoftwareReplies: 31Last Post: 12-04-2014, 12:49 AM -
HSM Advisor - High Speed Machining feed & speed calculator
By magicniner in forum CAD & CAM SoftwareReplies: 2Last Post: 20-01-2014, 12:57 PM -
Help! Steppers losing steps and making a racket under slow feed..
By fasteddy in forum Stepper & Servo MotorsReplies: 23Last Post: 06-08-2011, 03:03 PM -
Forum Slow
By pcstru in forum General DiscussionReplies: 3Last Post: 27-01-2011, 03:54 PM
