Thread: stepper speed very slow
thanks john
so my steps are set right , will try the settings you suggest, i knew i should be able to get a bit more speed somehow, if i can even get to 1000mm a min i will be happy
01-11-2009 #2
managed to get my speed up , wired the steppers bipolar single coil
at 2.5 amps the 3nm motors are down to about 2nm but the speed has increased quite considerably can get about over 1000mm/min
Need to slow down a signal due to Safe Torque Off alarm
By corkcnc in forum General ElectronicsReplies: 0Last Post: 04-06-2014, 11:35 PM -
Machine Slow on Curves
By swisscheese in forum Computer SoftwareReplies: 31Last Post: 12-04-2014, 12:49 AM -
HSM Advisor - High Speed Machining feed & speed calculator
By magicniner in forum CAD & CAM SoftwareReplies: 2Last Post: 20-01-2014, 12:57 PM -
Help! Steppers losing steps and making a racket under slow feed..
By fasteddy in forum Stepper & Servo MotorsReplies: 23Last Post: 06-08-2011, 03:03 PM -
Forum Slow
By pcstru in forum General DiscussionReplies: 3Last Post: 27-01-2011, 03:54 PM
