Hello everyone I am a new member and I would like to sell my 5 axis CNC milling machine. The machine has only been tested once. Excellent machine, manufactured in Serbia. Made 3d machine model as well as machine kinematics including post-processor for PowerMill. A unique machine custom mad for me.
I would appreciate advice what is the best way to sell this machine as fast as possible because I need funds for some other projects.
Main purpose: Numerical machine for curvilinear processing and engraving of wood, mediapan, plastic, styrofoam, aluminum. . . .
  • Machine moves in 5-axis mode X = 665, Y = 400 mm, Z = 589 mm (Z = 700 mm in 3-axis mode without tub with two extra axes), A = 360 *, B = + / - 120 *
  • Clamping items to the workbench via threaded steel inserts
  • Support structure, steel
  • Axis drive with step motors
  • Maximum speed 3400 mm / min
  • Water cooled machining engine 2.2kW
  • Maximum speed of the machining engine 24,000 rpm
  • Grip of milling cutters 3mm in diameter to 12.7mm in diameter
  • Frequency regulator HYUNDAi N700E 2,2kw
  • 3D processing
  • All 5 axes controlled simultaneously
  • Connecting to a computer: LPT - parallel port
  • Precision 0.02 mm
Machine also comes with a sets of completely new milling tools and tools holders. Click image for larger version.
