	13-03-2020 #1
Vortec cold air gun selling with spindle bracket and nozzle only used once original price £420 designed to cool bits while machining without using liquids just connect to air supply. No original box this item is listed elsewhere.
check site for more detail: https://www.vortextube.co.uk/cold-air-guns
Cold Air Guns
Cold Air Gun Close Up
Cold Air Guns incorporate a vortex tube in a system designed to fit the needs of many common vortex tube applications.
Features:
Cool without refrigerants (CFCs/HCFCs) or moving parts for reliable, trouble free operation.
Use no electricity intrinsically safe, no RF interference.
Include an integral muffler for quiet operation within OSHA noise specifications.
Are powered by filtered compressed air.
Vortec Cold Air Guns- Incredible Spot Cooling for Machining Operations
Cold Air Guns are used in various industrial processes, fabrication, assembly and packaging as a versatile spot cooling device. Most popular applications involve cooling during the machining of metals, plastics, wood, rubber, ceramics and other materials. Cold Air Guns provide effective cooling for most dry machining operations, allowing increases in feed rates and extending tool life. With no moving parts to wear out, the internal vortex tube converts factory compressed air into a sub-zero air stream, producing temperatures down to as much as -30°F.
Widely used in milling, drilling turning and other metalworking operations
Machining of plastics, composites, wood and other materials
Surface grinding, drill and tool sharpening
CNC routers, blades and bands saws
Spot cooling or parts molds and assemblies
Industrial sewing and textiles
Setting hot melts and adhesives
The Adjustable Cold Air Gun is ideal for use in machining applications and for cooling parts and industrial processes. The adjustable feature allows you to set the cold airflow rate (BTUH) at optimum levels for your application. The Adjustable Cold Air Gun’s maximum temperature drop is 55.6C° below inlet air temperature and the maximum cooling capacity is 378kcal/H.
Price: £370 including shipping within the UK
FOR SALE: Commander Drive Spares (Free) / High Pressure Water Pump / Cooler (Free)
By Chaz in forum Items For SaleReplies: 0Last Post: 05-09-2018, 12:14 PM -
RFQ: Cooler probe
By DAHammond in forum Projects, Jobs & RequestsReplies: 0Last Post: 10-06-2015, 05:18 PM -
How much does the cold affect the cnc router
By Steven W in forum Gantry/Router Machines & BuildingReplies: 9Last Post: 24-11-2013, 02:56 PM -
RFQ: 3D Model
By petesos in forum Projects, Jobs & RequestsReplies: 3Last Post: 01-01-2013, 10:31 PM -
DIY CPU water cooler
By wiatroda in forum Electronic Project BuildingReplies: 15Last Post: 06-04-2011, 11:44 AM
