Thread: KX3 Spindle Problem
	14-03-2020 #4
Ok well that's simple enough to check. Disconnect the wires going to the Spindle control board and measure the voltage at commanded speeds. If you haven't changed any of the Spindle settings in control software (mach3 I presume) then you should get 10v at full commanded speed. If you don't then it's the BOB at fault not the spindle control board.
If you have changed the spindle settings then I can't help anymore without knowing the BOB your using, but Knowing John S it won't be anything too fancy as he liked to keep it simple and cheap.
Huanyang VFD and spindle problem - VI/GND drawing voltage from my controller
By Mr*Beaver in forum Spindles & Drive MotorsReplies: 6Last Post: 20-12-2018, 03:40 PM -
Seig C3 CNC spindle problem
By Leadhead in forum Machine DiscussionReplies: 11Last Post: 15-08-2018, 08:12 AM -
By BriceO in forum Spindles & Drive MotorsReplies: 20Last Post: 07-08-2018, 08:56 AM -
Problem with Spindle not spinning
By Noplace in forum Spindles & Drive MotorsReplies: 4Last Post: 22-01-2016, 02:40 PM -
CNC spindle control VFD problem
By djc in forum Motor Drivers & ControllersReplies: 1Last Post: 13-09-2009, 09:26 PM
