  1. #8
    looks to me like there's a group of 3 capacitors near the center of the board and the middle one looks like it's blown.?
    Pfft, you have better eyes than me.
    I did google the KX3 when Ken first posted - I think I agree with the C11 board and this was the original spec for the machine so a like-for-like replacement at the time? A new card is (only?) $68 and if OP has the confidence to replace then it might be the easiest solution all around. The chip that's going to be responsible for the analogue output is the LM<something-or-other> on the far left of the photo. That's likely a £1 replacement, though it could be with the ancillary circuitry around there (caps, resistors) or the opto-isolator (the white chip), or the power from the spindle-controller card (I'd expect that to export 12Vdc to the BOB for the purpose of isolated power supply between the BoB logic and the spindle-controller) - worth checking that.
    OP: If you find yourself in a rabbit hole with this (and I don't think you need to) if you're prepared to post the board I could always take a look to overhaul it. That's a casual offer - I think it'd be quicker/easier for you to contact CNC4PC in the first instance.
    EDIT:
    Just re-reading the thread, OP - if you have the 10V supply from the spindle board then try throwing a 10k potentiometer across this and the spindle 0V, with the wiper connected to the analogue input - that should give you full manual control of the spindle speed and verify that the spindle board is okay - just to confirm the BOB is suspect. (there's a chance of a fault on the spindle board dragging the analogue output from the BOB down - this just helps to isolate the problem).
  1. Replies: 6
    Last Post: 20-12-2018, 03:40 PM
  2. Seig C3 CNC spindle problem
    By Leadhead in forum Machine Discussion
    Last Post: 15-08-2018, 08:12 AM
  3. Huanyang VFD and spindle problem
    By BriceO in forum Spindles & Drive Motors
    Last Post: 07-08-2018, 08:56 AM
  4. Problem with Spindle not spinning
    By Noplace in forum Spindles & Drive Motors
    Last Post: 22-01-2016, 02:40 PM
  5. CNC spindle control VFD problem
    By djc in forum Motor Drivers & Controllers
    Last Post: 13-09-2009, 09:26 PM
