Thread: Help with CNC 3018 from Banggood
14-03-2020 #4
Ok well if De-bounce allowed it to work then you are obviously suffering from noise issues so now you need to lower the de-bounce back to Zero, the reason for this is because it slows the switch response time so can be unsafe, and go with a solution like Doddy mentions where you pull the input high or low to stop it floating.
If after this you still get noise issues then there are other methods, like Opto's and Capacitors, etc but won't get into that now because I'm 99% sure fixing the floating input will work.
3018 Pro has no connectivity on A5 pins.
By deepcut66 in forum Chinese MachinesReplies: 0Last Post: 29-02-2020, 10:48 AM -
3018 3 Axis Mini DIY CNC Router ONLY Ł125 with free shipping !!!
By Lee Roberts in forum Marketplace DiscussionReplies: 6Last Post: 09-01-2020, 09:00 PM -
3018 problem
By bazbalz in forum Machine DiscussionReplies: 8Last Post: 17-12-2019, 12:58 PM
