    I have a Machine at home am working on photo below
    But we did try a machine via Ebay had some issues with the software when sorted that found it was no good to slow and noisy
    We are still looking to the same job at work but needs to be fast as has to wrap some stainless wire between some posts in 5 seconds ish
    Looking for recommendations ideas
    Thinking of building new unit but with faster pitch lead screws ?
ID:	27610   Click image for larger version.
    Ok well, several factors will come into play to do this and get the speed and acceleration you'll need. The screw is one but motors, drives and PSU are also very important and if you want really fast so is the controller. I'm going to assume your thinking to use Stepper motors rather than servo's to keep costs down.
    First, the screw indeed would benefit from being a higher pitch but it also needs to be the smallest diameter possible to keep the inertia down, this will allow higher accelerations which you'll probably need.
    Next, the Motors need to be a low inductance motor so they can spin faster and hold torque higher up the speed curve, these need to be connected to drives that allow a decent amount of voltage. Steppers get there speed from Voltage so the relationship between inductance and voltage is key.
    The PSU is also important with fast-spinning motors and screws because it needs to be able to handle any power being sent back from the dynamo effect when de-accelerating from high feeds.
    Now, 8mtr/min isn't fast for a router and any of the setups we use for a good router will easily top 10mtr/min humping a decent weight gantry around so I'm going to spec this like it's a medium-sized router and based on using Steppers.
    Motors:
    3 or 4Nm 8 wire nema 23 with an inductance around 3-4mh. The 8 wire type is preferred because can wire it parallel to get the best speed.
    Drives:
    Digital drive with Max voltage 70-80Vdc or 40-60Vac, it's becoming more common for drives to offer both DC and AC as it's easier regards PSU.
    PSU:
    If using DC then unregulated PSU is required and the best choice is one made using toroidal transformer and capacitors which is sized to your needs.
    This type of PSU allows the capacitors to absorb any power coming back and also provides a nice smooth supply of power for the drives. The transformer will need to be sized to suit the drives/motors so I won't spec that now. When you have decided what your using I will help you choose the transformer.
    If using AC drives then it's simply a case of sizing transformer slightly(roughly 10%) smaller than the drives Max voltage.
    Screws:
    16mm Diameter 10mm pitch will work and because your probably not going to be lugging a heavy gantry around then with the above electrical spec you should easily reach 15mtr/min. If you wanted more speed then go with 16mm pitch and you'll be into 25mtr/min region.
    Controller:
    For high speeds and reliability, you really need a good controller. The parallel port is limiting in the number of pulses it can provide and the faster you go the more you need. It's also very flaky so best avoided.
    So external motion controllers are often used, some use USB but the best to use are Ethernet-based because they are most reliable.
    There are several manufacturers but common good ones are Cslabs and Motion controls products UC based controllers like UC300. Any of these will allow you to what you want.
    Hope this helps. Ask if need to know any thing more.
  1. Replies: 0
    Last Post: 15-12-2019, 09:44 PM
  2. 4th Axis Work Holding For Rectangular Work
    By magicniner in forum Workshop & Equipment
    Last Post: 20-10-2019, 03:02 AM
  3. NEW MEMBER: Hi. Heres my work
    By Ukmiller in forum New Member Introductions
    Last Post: 14-05-2017, 09:16 AM
  4. RFQ: I am looking for work as cnc operator.
    By krystiankania in forum Projects, Jobs & Requests
    Last Post: 13-02-2014, 03:48 PM
  5. NEW MEMBER: Back to work!
    By Edge in forum New Member Introductions
    Last Post: 19-08-2010, 11:57 PM
