    Hi
    Not a lot of help I'm afraid, I have been running an 860 at a "men's shed" for the last 3 years and I think there may be a manual there. Unfortunately the shed is closed until further notice. I modified it to 1605 ball screws as feed rates with the 2mm pitch original screws were far too slow, also built a new control panel using "Estlcam" software.
    I also have at home a 600 which I have modified to 1605 screws and servos, so do have quite a lot of spares if needed.
    Quote Originally Posted by johnsattuk View Post
    Hi
    Hi Johnsattuk
    Thanks for the reply, when the shed reopens I would appreciate it if you would have a look for the manual, I have considered just buying a new control card and running in on something like mach3 but if I can it will get it running as is first , do you know what the max speed on the table was , I will let you know if I discover I need parts ,
    Thanks again ,
  1. Centre Drills
    By jamesthomsan in forum Tool & Tooling Technology
    Last Post: 03-02-2020, 12:23 PM
  2. scm tech 95l cnc machining centre User manual or parts lists
    By george uk in forum SCM Group Routers
    Last Post: 28-04-2015, 08:18 AM
  3. FOR SALE: Boxford Vertical Machining Centre 190VMC Excellent Condition
    Last Post: 12-11-2014, 09:54 AM
  4. Dust and Chip extraction for large matrix table machining centre.
    By gavztheouch in forum Dust Extraction & Collection
    Last Post: 29-05-2013, 10:03 PM
  5. Centre tap transformer?
    By veedub1955 in forum General Electronics
    Last Post: 15-05-2012, 11:10 PM
