22-03-2020 #3
Thanks pippin88, I think am leading to the same conclusion as you. My diagram wasn't the best, the rails will be on the tube going across only (along the x axis), the diagram shows that it also goes across the small section of box that is going in the Y direction but this won't be the case since this space will be used to house a motor and leadscrew bearing support, so the rails only sit on one section of tube.
By "more solid" do you mean by adding bracing? This is something I will be doing for sure. Yes they will be welded, though I am considering welding the highest x-axis guide box to the top of the frame and bolting the one closest to the ground to make fine adjustment in reference to the welded one, haven't thought this completely through yet. Do you have pictures, or a build log ? it would be great to see your machine Thanks for your input
Originally Posted by Kitwn
Looking for advice on the designs of these components for 3 axis CNC milling.
By Neil C in forum General DiscussionReplies: 5Last Post: 16-07-2017, 10:38 AM -
NEW MEMBER: Hello is anyone interested in swapping CNC furniture designs?
By robgibcnc in forum New Member IntroductionsReplies: 0Last Post: 17-06-2017, 08:39 AM -
FOR SALE: For sale Nema 34, single axis table (Not for CNC), ballscrew with rods, bearings/
By Desertboy in forum Items For SaleReplies: 1Last Post: 07-05-2017, 02:30 PM -
Y-Axis Designs
By Cyclonit in forum Gantry/Router Machines & BuildingReplies: 2Last Post: 24-06-2014, 02:20 PM -
taper roller bearings vs deep groove ball bearings
By dsc in forum Linear & Rotary MotionReplies: 8Last Post: 10-03-2014, 08:06 AM
