    These are the AC contact bearings I plan on using when I replace the rubish deep grove bearings in my Chinese BK12's for my Z axis.
    http://www.wychbearings.co.uk/7001-2RS-MAX-Enduro.html
    I haven't got them yet, so I can't comment on quality.
    For my X and Y axis I made my own bearing block as dazp1976 suggested using larger bearings and my mini-lathe. Although if I knew wynchbearings sold 7001 at a reasonable price way back when I made them I would have just bought cheap BK12s and replaced the bearings.
    I found I had to shim my AC bearing to remove play. I used a mixture of 0.1mm shim washers and some thinner ones I cut out of some brass shim shock. They all feel rock solid now.
    https://www.ebay.co.uk/itm/A2-Stainl...DHNWICz7gz71SQ
  2. The Following User Says Thank You to diycnc For This Useful Post:
  3. #2
    Quote Originally Posted by diycnc View Post
    I've been using these a while.
    https://www.ebay.co.uk/itm/7201-B-2r...oAAOSwBRVaWdEz
    In terms of needing shimming it depends on how you make your blocks to house them. Mine need none, just have to watch how tight I do the end nut.
    I've now ordered these to go on the floating end: https://www.ebay.co.uk/itm/3200-B-2R...72.m2749.l2649
    I've found that if I put a bearing up tight on this end it eliminates about 0.02mm of my 0.035mm of backlash. A little bit of flex in the screw by the looks of it.
  1. Replies: 0
    Last Post: 23-01-2018, 11:15 AM
  2. Replies: 15
    Last Post: 05-01-2016, 08:52 AM
  3. taper roller bearings vs deep groove ball bearings
    By dsc in forum Linear & Rotary Motion
    Last Post: 10-03-2014, 08:06 AM
  4. What metalwork lathe should I get to replace Sieg C3
    By Jonathan in forum Milling Machines, Builds & Conversions
    Last Post: 28-02-2011, 01:41 AM
  5. BK12 & BF12 bearings
    By mlmSolutions in forum Lead Screws, Nuts & Supports
    Last Post: 04-01-2011, 11:16 AM
