26-03-2020 #9
I've been using these a while.
https://www.ebay.co.uk/itm/7201-B-2r...oAAOSwBRVaWdEz
In terms of needing shimming it depends on how you make your blocks to house them. Mine need none, just have to watch how tight I do the end nut.
I've now ordered these to go on the floating end: https://www.ebay.co.uk/itm/3200-B-2R...72.m2749.l2649
I've found that if I put a bearing up tight on this end it eliminates about 0.02mm of my 0.035mm of backlash. A little bit of flex in the screw by the looks of it.Last edited by dazp1976; 26-03-2020 at 06:08 PM.
FOR SALE: Ballscrews 1400mm 1605 with BK12/BF12 fittings, flexible coupling, nema 23 almost new
By Desertboy in forum Items For SaleReplies: 0Last Post: 23-01-2018, 11:15 AM -
Any experience or software for Control Techniques FNC4? Wha do I replace it with?
By mitip in forum Motor Drivers & ControllersReplies: 15Last Post: 05-01-2016, 08:52 AM -
taper roller bearings vs deep groove ball bearings
By dsc in forum Linear & Rotary MotionReplies: 8Last Post: 10-03-2014, 08:06 AM -
What metalwork lathe should I get to replace Sieg C3
By Jonathan in forum Milling Machines, Builds & ConversionsReplies: 7Last Post: 28-02-2011, 01:41 AM -
BK12 & BF12 bearings
By mlmSolutions in forum Lead Screws, Nuts & SupportsReplies: 0Last Post: 04-01-2011, 11:16 AM
