Thread: Cutting Wood veneer
25-03-2020 #2
Just off the top of my head, I haven't tried this:
Glue the veneer to some scrap MDF that goes on top of the piece. Cut it out (you may have to build a small vacuum table), inlay and then machine off the MDF.
There's a cunning method using V-carve which could be adapted to suit at the link below (it says 'video' in the link but is actualy a .pdf document)
Kit
http://www.vectric.org/video/aspire4..._Procedure.pdfAn optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
Birch plywood and veneer sources ?
By threedee in forum Woodwork DiscussionReplies: 6Last Post: 31-01-2023, 11:08 PM -
cnc crashes when cutting 2D profiles in wood
By chrisobrien07 in forum Woodwork DiscussionReplies: 10Last Post: 16-11-2021, 09:38 PM -
Cutting Wood veneer
By Britannicus1 in forum General DiscussionReplies: 2Last Post: 19-01-2020, 11:59 AM -
Where to buy plywood veneer in UK?
By carol in forum Woodwork DiscussionReplies: 2Last Post: 14-09-2017, 08:34 PM -
I need a Good CNC Machine for cutting letters out of wood for under 800.00
By theceo in forum Machine DiscussionReplies: 6Last Post: 02-04-2016, 12:48 PM
