Thread: Cutting Wood veneer
Would soaking the veneer with water when you dissolve the glue lead to swelling/shrinking that ruins the accurate sizing of the piece? Only experiments will show.
There are plenty of ideas for cheap and cheerful vacuum tables for small areas. Worth a google before you decide that's not an affordable option.An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
Birch plywood and veneer sources ?
By threedee in forum Woodwork DiscussionReplies: 6Last Post: 31-01-2023, 11:08 PM -
cnc crashes when cutting 2D profiles in wood
By chrisobrien07 in forum Woodwork DiscussionReplies: 10Last Post: 16-11-2021, 09:38 PM -
Cutting Wood veneer
By Britannicus1 in forum General DiscussionReplies: 2Last Post: 19-01-2020, 11:59 AM -
Where to buy plywood veneer in UK?
By carol in forum Woodwork DiscussionReplies: 2Last Post: 14-09-2017, 08:34 PM -
I need a Good CNC Machine for cutting letters out of wood for under 800.00
By theceo in forum Machine DiscussionReplies: 6Last Post: 02-04-2016, 12:48 PM
