Thread: Inductive Limit Switch problem
12-04-2020 #18
Not measured on a specific opto, but it is the measured output voltage of the proximity sensor when triggered. Opto outputs will vary depending on device and load current but with only 0.6V to play with I'm not chancing it. I was surprised at the low trigger voltage, but it's what I measured on the board input and the chip spec says it can be as low as 0.7V
This is likely to be a problem with any board that only uses 5V logic on it's inputs. I assume the more expensive boards are more sophisticated. They'd better be for the difference in price.
I'm happy that the 10K pull-up on the board will work OK with the single pole relays. The relay will isolate the actual board input from any noise on the wiring from the sensors and the overall noise level is going to be significantly reduced by my improvements to the wiring overall.An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
Limit switch problem
By ECCO in forum General ElectronicsReplies: 7Last Post: 25-12-2015, 11:28 AM -
Which Type of Limit Switch
By manofgresley in forum General ElectronicsReplies: 52Last Post: 29-07-2014, 03:43 PM -
Limit switch issues?!?
By jonbabbz in forum General ElectronicsReplies: 10Last Post: 06-02-2014, 07:37 PM -
One limit switch per axis
By EddyCurrent in forum General ElectronicsReplies: 17Last Post: 30-09-2013, 11:38 AM -
Limit switch Cable ...
By Wobblybootie in forum General ElectronicsReplies: 3Last Post: 17-01-2011, 04:37 PM
