Thread: Inductive Limit Switch problem
23-04-2020 #29
I was just getting to the end of all the new wiring when the same nice man in the same white van turned up with another parcel from RS containing the relays. Apart from a slight problem mentioned elsewhere I now have the 4 new proximity sensors wired up with screened cables back to the controller and the relay/transistor interface into the BOB finished and tested.
Tomorrow I will tidy up the impressive mess and get everything put back together and ready for testing and alignment. Auto-squaring will need to be re-calibrated and the finished aluminium (rather than the old plywood prototype) Z axis lined up as well. Might be able to make something soon!An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
Limit switch problem
By ECCO in forum General ElectronicsReplies: 7Last Post: 25-12-2015, 11:28 AM -
Which Type of Limit Switch
By manofgresley in forum General ElectronicsReplies: 52Last Post: 29-07-2014, 03:43 PM -
Limit switch issues?!?
By jonbabbz in forum General ElectronicsReplies: 10Last Post: 06-02-2014, 07:37 PM -
One limit switch per axis
By EddyCurrent in forum General ElectronicsReplies: 17Last Post: 30-09-2013, 11:38 AM -
Limit switch Cable ...
By Wobblybootie in forum General ElectronicsReplies: 3Last Post: 17-01-2011, 04:37 PM
