Thread: Inductive Limit Switch problem
31-03-2020 #10
As per the previous post, combining these switches in series isn't a probem as you combine the switches at each end of the same axis - don't mix axes. As long as you have each axis (including A and X if it's a dual-axis machine) going to a separate input, that also lets you home more than one axis at a time. You need to do that anyway if you have a dual-axis machine and want proper gantry squaring on homing.
Personally I run spindle, motor, and switch cables all in the same cable chain; they are all CY and I use 24V signalling which helps with noise rejection. Don't have noise problems.I do have a solid earth wire running through each cable chain connecting the two end parts to avoid any need for continuity via the bearings. Haven't noticed the LEDs glowing. I did wonder if you had bad switches; I bought a cheap box of 10 from eBay when I built my machine and one was the wrong type (only had two wires coming out which was a bit of a giveaway), one was bad when I fitted it, and one failed shorty afterwards. Been OK since, though.
Limit switch problem
By ECCO in forum General ElectronicsReplies: 7Last Post: 25-12-2015, 11:28 AM -
Which Type of Limit Switch
By manofgresley in forum General ElectronicsReplies: 52Last Post: 29-07-2014, 03:43 PM -
Limit switch issues?!?
By jonbabbz in forum General ElectronicsReplies: 10Last Post: 06-02-2014, 07:37 PM -
One limit switch per axis
By EddyCurrent in forum General ElectronicsReplies: 17Last Post: 30-09-2013, 11:38 AM -
Limit switch Cable ...
By Wobblybootie in forum General ElectronicsReplies: 3Last Post: 17-01-2011, 04:37 PM
