Thread: Inductive Limit Switch problem
OK, after serious consideration my priority has to be getting the #$%^*&^%$#@ing machine actually working so I can make some stuff with it. Playing about with circuit ideas is fine, but...
I'm not wasting a long weekend off work waiting for RS to send me some new cable and other components including 2mm pitch plugs for the PCB headers, so I've made a circuit board which connects into the existing screw terminals without the need to remove/replace surface mount components on the BOB itself. I expect it's going to work. If so, it'll do for now and I'll make a more reliable change to the wiring later. This machine is after all just a toy in my shed rather than the heart of a commercial operation.
Watch this space for details if it works!An optimist says the glass is half full, a pessimist says the glass is half empty, an engineer says you're using the wrong sized glass.
Limit switch problem
By ECCO in forum General ElectronicsReplies: 7Last Post: 25-12-2015, 11:28 AM -
Which Type of Limit Switch
By manofgresley in forum General ElectronicsReplies: 52Last Post: 29-07-2014, 03:43 PM -
Limit switch issues?!?
By jonbabbz in forum General ElectronicsReplies: 10Last Post: 06-02-2014, 07:37 PM -
One limit switch per axis
By EddyCurrent in forum General ElectronicsReplies: 17Last Post: 30-09-2013, 11:38 AM -
Limit switch Cable ...
By Wobblybootie in forum General ElectronicsReplies: 3Last Post: 17-01-2011, 04:37 PM
