Thread: Inductive Limit Switch problem
That UCSB board, on paper, looks to be a pretty good BoB for the extra ports on (at least) the UC300ETH. It's pricey, though, but looks to be built like the proverbial brick-outhouse. Probably a bit of an overkill for most machines (how many layers of optical isolation do you really need?) but if you're happy with the price. I'd be thinking that if I was ever to need more than the 12 outputs (bearing in mind you'll need 8-9 for a 4-axis) then I'd relegate the axis stepper signals to a cheaper BoB on the port 2/3 on the 300 and retain the highly flexible I/O of the UCSB for other purposes on the machine.
Limit switch problem
By ECCO in forum General ElectronicsReplies: 7Last Post: 25-12-2015, 11:28 AM -
Which Type of Limit Switch
By manofgresley in forum General ElectronicsReplies: 52Last Post: 29-07-2014, 03:43 PM -
Limit switch issues?!?
By jonbabbz in forum General ElectronicsReplies: 10Last Post: 06-02-2014, 07:37 PM -
One limit switch per axis
By EddyCurrent in forum General ElectronicsReplies: 17Last Post: 30-09-2013, 11:38 AM -
Limit switch Cable ...
By Wobblybootie in forum General ElectronicsReplies: 3Last Post: 17-01-2011, 04:37 PM
