Thread: Inductive Limit Switch problem
Yes, a lot of the big industrial gear does that. They use a ground fault detection circuit to look for a fault to ground and flag up a warning if one is seen, rather than bombing out immediately. That allows the system to continue running until it can be brought safely to a halt. This can be handy if you happen to be operating eg an elevator lift or a paper / steel mill at the time.
You can always connect the floating node to ground via a Y cap to stop it flying about so much. This gives the noise a path back to ground without the danger of a DC path popping your drives or controller.
Limit switch problem
By ECCO in forum General ElectronicsReplies: 7Last Post: 25-12-2015, 11:28 AM -
Which Type of Limit Switch
By manofgresley in forum General ElectronicsReplies: 52Last Post: 29-07-2014, 03:43 PM -
Limit switch issues?!?
By jonbabbz in forum General ElectronicsReplies: 10Last Post: 06-02-2014, 07:37 PM -
One limit switch per axis
By EddyCurrent in forum General ElectronicsReplies: 17Last Post: 30-09-2013, 11:38 AM -
Limit switch Cable ...
By Wobblybootie in forum General ElectronicsReplies: 3Last Post: 17-01-2011, 04:37 PM
