  1. Quote Originally Posted by John S View Post
    Every chance.
    One other detail required on gears is to know the pressure angle, PA, the involute [ shape of gear tooth ] is generated at.
    Modern gears are cut at 20 degrees, older gears at 14.5.
    Bad news is it's really hard to measure a PA in the home shop without specialist equipment.
    Good news is most machine tool maker use 14.5 and stick to it because of legacy issues.
    Early Colchesters also had 16DP gears at 14.5 PA.
    Both DP16, but his are 3/8 wide and mine 5/8. Also I have 55 and 65 while his set includes 56 and 64 so maybe intended for a different pitch leadscrew (mines 8tpi)
    Width and pitch of leadscrew have nothing to do with whether the gears will fit.
    That's all down to the DP and whether they have the numbers of teeth you require.
    John S -
  3. No I realise that John, but it does have a bearing on whether the gear set is useful for cutting standard threads... if i can't make meaningful trains with the pitch of leadscrew then there's no point in buying them.
  1. Ok, so whats wrong?
    By Davek0974 in forum 3D Printing Machines
    Last Post: 27-03-2014, 12:19 PM
  2. RFQ: Looking to get a couple gears modded
    By m_c in forum Projects, Jobs & Requests
    Last Post: 23-11-2013, 09:34 PM
  3. Whats It Worth
    By Jay in forum General Discussion
    Last Post: 21-01-2012, 09:08 PM
  4. whats the matter!
    By ptjw7uk in forum General Discussion
    Last Post: 29-11-2009, 07:21 PM
  5. Safe Z Arghhhhhhhh!! Whats going on!
    By AdCNC in forum Machine Discussion
    Last Post: 18-08-2009, 05:15 PM
