Thread: My sizes are out
Not really no. Even if it has backlash it will still follow the same pattern back and forth so you wouldn't notice.
Have a look at some vids that show how to properly check it.
If your sizes are out by more than say 0.2mm I'd say it wasn't a backlash issue. I've never really seen backlash values of more than 0.08mm which would make a circle smaller by only 0.16mm.
04-04-2020 #2
If you had 1mm of backlash you'd feel it by shaking each axis, it would feel like it's falling off.!
04-04-2020 #3
Tell me about it!!
1 thing I'd say as well is I often use cheap nasty Chinese cutters for roughing through then swap a decent cutter for a finish.
Those Chinese ones can vary in size a chunk.
I can rough a new 6mm 3flute bit using it to finish as well and I won't fit a bearing in the hole.
Then next I'll leave 0.5mm on with the same cutter, swap it for a 4flute Cobalt bit for finishing and be able to just get the bearing in.
That's with my drawings modified where a circle is set 0.1mm lager than I actually want it.
My Benchtop only has 3000rpm at the spindle so I find Cobalt work better for me as I can hog it a tiny bit.
Those Carbide bits are designed for higher rpm and I've shattered a few so there used for finishing only too.
04-04-2020 #4
No, that will not show backlash.
Look up what it is and how to check it.
You need a proper measuring instrument, e.g a dial indicator. You move the axis in one direction into the dial indicator, zero the dial indicator then move the axis in the opposite direction a defined amount. You then check the dial indicator reading and compare to what it should be.
04-04-2020 #5
A couple of experiments for you to try.
*** CAUTION: Hand coded G-Code and un-tested. Sit next to your E-Stop!!! ***
test2.nc
This should slowly rock the X-axis by 0.5mm (or 18 degrees on a 1610 screw) - wrap a bit of tape around the x-axis screw with a visible tail and run this g-code through the controller and observe the tape. The G-code has got a feed rate of 10mm/min so my poor maths suggests around 3 seconds to go 0.5mm (18 degrees) and 3 seconds to go back to 0 (0 degrees). It repeats... a few times. No spindle and no z-movement.
This is just to verify that there's no backlash compensation active erroneously or not in the controller. You'll have to eyeball the 18 degrees rotation on the screw/tape.
Remove tape.
test.nc
This one cuts two pocket outlines - with your 12.7mm milling bit, starts at (0,0) and cuts a 3-tooth comb with a positive displacement on X, 50mm between teeth. After the 3rd tooth it reverses and cuts another 2 teeth offset in Y 30mm back the other way also 50mm apart. This to verify again that there's no backlash effects or compensation in operation.
Sorry, that's all I can think of at the moment.
The Following User Says Thank You to Doddy For This Useful Post:
04-04-2020 #6
The Following User Says Thank You to Boyan Silyavski For This Useful Post:
06-04-2020 #7
I had a blonde moment today, I dug out my old pc which has linuxcnc on it and brought it home to try with the machine I was just going to wire the X,Y,& Z see if the sizes are still out and if so are they out the same amount.
When I got home to set it up I forgot a VGA monitor lol, no HDMI out on this machine.
I need to go work again tomorrow so will have to wait another day.
At the moment I've set the motors to ~3amps on the stepper drivers by jumpers they should be ~ 4amps and they don't get warm even after hours of machining but I will connect them to the PC so I can autotune everything.Last edited by Desertboy; 06-04-2020 at 02:46 PM.
WANTED: TG 100 Collets in various sizes
By gavztheouch in forum Items WantedReplies: 4Last Post: 28-10-2016, 02:51 PM -
1:1 ratio - pulley sizes
By dsc in forum Belt Drive, Pulleys & TimingReplies: 3Last Post: 12-04-2014, 01:30 PM -
pulleys and belts - sizes
By mocha in forum Belt Drive, Pulleys & TimingReplies: 3Last Post: 22-07-2012, 05:16 PM -
Belt drive and pulley sizes
By j2sip in forum Belt Drive, Pulleys & TimingReplies: 22Last Post: 20-06-2010, 10:44 AM
