Page 1 of 5 123 ... LastLast
    Hi, I've been almost exclusively 3d carving and sign making never noticed my sizes are out.
    I cut a simple hose adapter a few times now and every time it's out but exactly the same amount, tried 3 different tools to cut it, from 1/2" to 1/8" end mills.
    I'm out by ~1mm on 33mm hole, the holes are round and all 4 cuts are out by the same amount, tried it fast and super slow the same.
    1610 Chinese ballscrew's from alixpress, direct drive, AM882's, 70v PSU, motors barely get warm after an hour of 3d carving.
    DDCSV controller generated gcode in Fusion and vcarve same results.
    What can be causing it and how do I solve it?
    Sounds like your "steps per unit" calculations have gone a bit wrong. Can you recheck, or post all relevant data here so someone else can check your working?
    The other way of doing it is starting with a good first guess - which you have - and then modifying the "steps per" based on the results of a calibration run. Personally, if my calculated value were out by more than a tiny amount then I reckon something's wrong - my calculation or a machine error. Slipping coupling, missing steps, or whatever. However, others take the more empirical approach. In short - keep tweaking until you get the right answer! Mach3 actually has a calibration capability built-in but don't know about your controller.
    On the ddscv it's steps per mm
    I have 8 microsteps
    so 8*200/10 (1610's) for X&Y 160
    320 for Z (1605)
    Just double checked this is definitely what they are set to.
    AM882 has fault protection it should detect missing steps and estop and I swapped all the couplings for these style, I bought the chunkier ones.
    so they're rated twice the nm of the motors.
    2 4nm in the bottom and 3nm on the gantry, PSU is 70v and 1kva.
    Will try and cut 3 holes at 33mm, 66mm and 99mm see if the error scales perfectly I tried cutting from speed of 0.5m/min to 10m/min exactly the same results.
    Carved a lot of 3d stuff on this machine and that's machining for hours not seeing issues there or sign making never noticed the size was wrong until I tried to make an adapter and it didn't fit.
    Both X&Y are out by the same amount not sure about the Z.
  5. #4
    I have 8 microsteps
    320 for Z (1605)
    The numbers are really only to get you in the ball park. There's always a slight error on the screws.
    Mine is similar on circles. I end up about 0.1mm too small so I just tweek my drawings to suit the machine. I add 0.1mm to inner circles such as do a 32mm as a 32.1mm.
    Then outer edges I add 0.05mm on each end (or I can set my stock to leave 0.05mm instead).
    This will give you a rough idea on methods of how to increase accuracy using Mach calibration. Or at least to check how close your machine is to see if that is the problem.
    https://www.youtube.com/watch?v=XkO5tc-jSxw
  6. #5
    AM882 doesn't detect missing steps it's got stall detection which is a different thing altogether. It also only works above 300Rpm.
    Regards the wrong size parts then if the steps per is correct and you don't have slippage etc then I would be looking to the CAM and the tool offsets.
    Does the controller have tool offsets.?
  8. #6
    Sounds good to me. I'll step back and wait for the experts to comment!
  9. The Following User Says Thank You to Neale For This Useful Post:
  10. #7
    I measured all 4 parts with calipers within 0.05mm of each other but just not the right size.
  11. #8
    What should the rising edge be set to?
    I have it set to uprising at moment
  12. #9
    It depends on the controller and whether it looks at the rising or falling edge.
    However it's easy to test. Just write some G-code that moves back n forth few hundred short moves, say 10mm, then back to zero. If you have the wrong edge set it will lose a step for every direction change and it won't return to zero. Do this for each axis separately.
  13. The Following User Says Thank You to JAZZCNC For This Useful Post:
  14. #10
    OK I drilled a small hole just outside my normal machining area set that as X&Y 0
    then created code to
    G01 X10
    G01 X0
    1000 times doesn't seem to have shifted
    just running the Y code now
    Will try Z after that.
    Can I do something similar to see if I'm losing steps?
    Or is there some test code for that?
    In the manual there's "Level of Axis pulse signal" what does this mean? Is that the rising/falling edge?
Name:	level pulse signal.png
  1. WANTED: TG 100 Collets in various sizes
    By gavztheouch in forum Items Wanted
    Last Post: 28-10-2016, 02:51 PM
  2. 1:1 ratio - pulley sizes
    By dsc in forum Belt Drive, Pulleys & Timing
    Last Post: 12-04-2014, 01:30 PM
  3. pulleys and belts - sizes
    By mocha in forum Belt Drive, Pulleys & Timing
    Last Post: 22-07-2012, 05:16 PM
  4. Belt drive and pulley sizes
    By j2sip in forum Belt Drive, Pulleys & Timing
    Last Post: 20-06-2010, 10:44 AM
