Thread: My sizes are out
	03-04-2020 #31Apologies - somewhat out of context. My reference to "noise" is related to babble rather than advice and to the value (or lack thereof) to the continued thread, and not a suggestion at all of electrical noise.
 For absolute clarity - I do not mean electrical noise, for the reasoned evidence that Jazz gives.
    The Following User Says Thank You to Doddy For This Useful Post:
	03-04-2020 #32http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
	03-04-2020 #33
	03-04-2020 #34Have you tried with a different vernier caliper or always the same one?
    The Following User Says Thank You to phill05 For This Useful Post:
	03-04-2020 #35Always the same one but you can see a mm on a ruler which I also tried, the bit is a 1/2" trend router bit, and it's in a 1/2" collet so I think my calipers aren't the issue here.
 The pocket even using measuring tape I can see are 1mm undersized.
 BUT this gap is meant to be 100cm so the only thing I can think off is the controller is offsetting the tool.
 Thinking I might need to connect the X, Y & Z to a breakout board and do a test cut from linuxcnc super slow to see if that shows the same size issue.Last edited by Desertboy; 03-04-2020 at 04:19 PM. http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
	03-04-2020 #36This is a wild shot but suppose must be asked.! . . .You have trammed the spindle haven't you.? Does the bottom of the pocket measure same as the top.?
	03-04-2020 #37http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
	03-04-2020 #38
	04-04-2020 #39Have you measured your backlash? You need to check backlash.
    The Following User Says Thank You to pippin88 For This Useful Post:
	04-04-2020 #40A couple of experiments for you to try.
 *** CAUTION: Hand coded G-Code and un-tested. Sit next to your E-Stop!!! ***
 test2.nc
 This should slowly rock the X-axis by 0.5mm (or 18 degrees on a 1610 screw) - wrap a bit of tape around the x-axis screw with a visible tail and run this g-code through the controller and observe the tape. The G-code has got a feed rate of 10mm/min so my poor maths suggests around 3 seconds to go 0.5mm (18 degrees) and 3 seconds to go back to 0 (0 degrees). It repeats... a few times. No spindle and no z-movement.
 This is just to verify that there's no backlash compensation active erroneously or not in the controller. You'll have to eyeball the 18 degrees rotation on the screw/tape.
 Remove tape.
 test.nc
 This one cuts two pocket outlines - with your 12.7mm milling bit, starts at (0,0) and cuts a 3-tooth comb with a positive displacement on X, 50mm between teeth. After the 3rd tooth it reverses and cuts another 2 teeth offset in Y 30mm back the other way also 50mm apart. This to verify again that there's no backlash effects or compensation in operation.
 Sorry, that's all I can think of at the moment.
  WANTED: TG 100 Collets in various sizesBy gavztheouch in forum Items WantedReplies: 4Last Post: 28-10-2016, 02:51 PM
  1:1 ratio - pulley sizesBy dsc in forum Belt Drive, Pulleys & TimingReplies: 3Last Post: 12-04-2014, 01:30 PM
  pulleys and belts - sizesBy mocha in forum Belt Drive, Pulleys & TimingReplies: 3Last Post: 22-07-2012, 05:16 PM
  Belt drive and pulley sizesBy j2sip in forum Belt Drive, Pulleys & TimingReplies: 22Last Post: 20-06-2010, 10:44 AM
