Thread: My sizes are out
03-04-2020 #21
Well a quick look shows that it should cut a 50mm pocket. The last move is at 43.65 and the tool 12.7mm so should hit 50mm provided the tool really is 12.7mm
03-04-2020 #22
Ignoring all the individual line segments...
X lower extreme = 6.35, higher extreme = 43.65. Tool size specified as 12.7mm (6.35 rad), defines a X range of 0..50mm - I guess the operation...
line 231:
G01 X43.650 Y6.350 Z-3.000
G01 X43.650 Y43.650 Z-3.000
G01 X6.350 Y43.650 Z-3.000
G01 X6.350 Y6.350 Z-3.000
is the finishing pass, and should leave a 50mm pocket. Provided that your cutter is 12.7mm diameter.
The code is right (at least that should leave the pocket at the correct size). I'd look to answer Jazz's question on measured tool size. Beyond that, looking at the input to the DDSCV controller (GCode) is correct, you have the configuration of the DDSCV itself that I cannot advise, and the output measured... I'd say the controller is looking suspicious.
The Following User Says Thank You to Doddy For This Useful Post:
03-04-2020 #23
Hmmm, really basic question - you have measured backlash on the axis?
03-04-2020 #24
03-04-2020 #25http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
03-04-2020 #26
G-Code describes 50mm with a 12.7mm cutter. I reckon your machine is just plain haunted and we should all just self-isolate from it.
The bit that gets me is that it's a very precise 1mm error. But the G-Code is precise and correct.
03-04-2020 #27http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
03-04-2020 #28http://www.mycncuk.com/threads/10880...60cm-work-area My first CNC build WIP 120cm*80cm
03-04-2020 #29
I'm adding noise now to this thread which I don't want to do but I understand (I think) where Jazz is coming from - it's unlikely to be a tool offset or deliberate behaviour by the controller simply because the controller doesn't understand the geometry of the shape being cut - that's part of the CAM to apply the tool diameter offset performed by Fusion depending on the face being machined.
The only thing I can see in the manual are the backlash parameters 437..445 (DS DDCSV V3.1) that would likely have such an impact on behaviour, but even that I'm doubting as it is likely to introduce more steps, rather than reduce.
03-04-2020 #30
WANTED: TG 100 Collets in various sizes
By gavztheouch in forum Items WantedReplies: 4Last Post: 28-10-2016, 02:51 PM -
1:1 ratio - pulley sizes
By dsc in forum Belt Drive, Pulleys & TimingReplies: 3Last Post: 12-04-2014, 01:30 PM -
pulleys and belts - sizes
By mocha in forum Belt Drive, Pulleys & TimingReplies: 3Last Post: 22-07-2012, 05:16 PM -
Belt drive and pulley sizes
By j2sip in forum Belt Drive, Pulleys & TimingReplies: 22Last Post: 20-06-2010, 10:44 AM
