    Have you tried with a different vernier caliper or always the same one?
  2. The Following User Says Thank You to phill05 For This Useful Post:
  3. #2
    Always the same one but you can see a mm on a ruler which I also tried, the bit is a 1/2" trend router bit, and it's in a 1/2" collet so I think my calipers aren't the issue here.
    The pocket even using measuring tape I can see are 1mm undersized.
    BUT this gap is meant to be 100cm so the only thing I can think off is the controller is offsetting the tool.
    Thinking I might need to connect the X, Y & Z to a breakout board and do a test cut from linuxcnc super slow to see if that shows the same size issue.
    This is a wild shot but suppose must be asked.! . . .You have trammed the spindle haven't you.? Does the bottom of the pocket measure same as the top.?
  6. #4
    I can't remember if I did now, I've had the Z off a few times including changing the gantry rails, did I tram it last time?
    Will go check shortly.
  7. #5
    Actually, on reflection, it wouldn't make any difference the size would still be correct it's just your pocket walls would be a parallelllllll gram or what ever they are called..
  1. WANTED: TG 100 Collets in various sizes
    By gavztheouch in forum Items Wanted
    Last Post: 28-10-2016, 02:51 PM
  2. 1:1 ratio - pulley sizes
    By dsc in forum Belt Drive, Pulleys & Timing
    Last Post: 12-04-2014, 01:30 PM
  3. pulleys and belts - sizes
    By mocha in forum Belt Drive, Pulleys & Timing
    Last Post: 22-07-2012, 05:16 PM
  4. Belt drive and pulley sizes
    By j2sip in forum Belt Drive, Pulleys & Timing
    Last Post: 20-06-2010, 10:44 AM
