Thread: My sizes are out
04-04-2020 #36
Tell me about it!!
1 thing I'd say as well is I often use cheap nasty Chinese cutters for roughing through then swap a decent cutter for a finish.
Those Chinese ones can vary in size a chunk.
I can rough a new 6mm 3flute bit using it to finish as well and I won't fit a bearing in the hole.
Then next I'll leave 0.5mm on with the same cutter, swap it for a 4flute Cobalt bit for finishing and be able to just get the bearing in.
That's with my drawings modified where a circle is set 0.1mm lager than I actually want it.
My Benchtop only has 3000rpm at the spindle so I find Cobalt work better for me as I can hog it a tiny bit.
Those Carbide bits are designed for higher rpm and I've shattered a few so there used for finishing only too.
WANTED: TG 100 Collets in various sizes
By gavztheouch in forum Items WantedReplies: 4Last Post: 28-10-2016, 02:51 PM -
1:1 ratio - pulley sizes
By dsc in forum Belt Drive, Pulleys & TimingReplies: 3Last Post: 12-04-2014, 01:30 PM -
pulleys and belts - sizes
By mocha in forum Belt Drive, Pulleys & TimingReplies: 3Last Post: 22-07-2012, 05:16 PM -
Belt drive and pulley sizes
By j2sip in forum Belt Drive, Pulleys & TimingReplies: 22Last Post: 20-06-2010, 10:44 AM
