01-04-2020 #4
Many thanks Gents - and especially Clive for the detailed information. Those photos make for a very interesting story - you certainly made some far reaching upgrades to your Novamill!
Looks like you used a replacement board from eBay for your PWM to 10v conversion, and set your frequency at 1500Hz. As I mentioned, I am retaining the original converter, so I have no idea what its preferred frequency will be. Reading various sources were suggesting much lower rates, but seeing your board taking a higher frequency was interesting. Maybe I'll just have a play and see what frequencies I can use to get the desired 0 to 10v swing. I guess if I find a frequency that works, then that is as good as any!
Thanks also for the HAL fragments. Today's first job is adding them (or something very similar) to mine.....
Graeme
CONVERSION: Denford Novamill 1996 Conversion, Hints & Tips Appreciated
By Husky in forum Conversion Build LogsReplies: 28Last Post: 05-01-2019, 11:35 PM -
High frequency vfd 1500hz
By assadi in forum Spindles & Drive MotorsReplies: 0Last Post: 28-08-2018, 04:12 PM -
CONVERSION: Novamill mach conversion upgrade
By Benja in forum Conversion Build LogsReplies: 4Last Post: 18-09-2017, 09:23 AM -
Configuring Altivar 12 frequency regulator for PID control
By vesilp in forum Spindles & Drive MotorsReplies: 4Last Post: 28-01-2017, 04:26 PM -
CONVERSION: Denford Novamill Mach3 conversion
By Miller in forum Conversion Build LogsReplies: 28Last Post: 25-06-2015, 04:00 PM
