03-04-2020 #1
Hi Chaps,
I can switch the spindle on and off in Mach4 no problem but when I close Mach4 the spindle turns on. I presume this is due to a setting in the smoothstepper. I have stop/start and feed hold state set to "force off". Also I double checked the BOB spindle relay is n/o.
Also how do I configure the spindle to run in 0-10v mode? My BOB does not have a pin no for the 0-10v o/p how do I allocate it in ESS pins config?
Finally does the BOB convert the PWM to anologue volts?
BOB is generic "ECG Savebase"
David
04-04-2020 #2
Your BOB does not support Spindle except in Relay mode / the relay switches it off and on/ . So no PWM, no 0-10V. forget about that
Hence in ESS manual is explained how to properly set the spindle in that mode.
It could be done with additional board but easier and cheaper will be probably to buy a better BOB, best with integrated transformer or converter for the 0-10v/ 0-5v ,most spindles /VDFs/ support both modes
And about that ON/Off problem. Remove power to the board and try connecting the relay outputs to see if problem persists. So you remove board from equation or problem is in the relay of the board, or the way you have programed that relay in Mach3 outputs
05-04-2020 #3
Thanks Boyan so the BOB will not support spindle speed I think I'll try Bill Caldwells method using Modbus RTU rather than replacing the BOB as the usb to RS485 converter is only a fiver on eBay.
Re the other advice I confirmed it is settings in Mach4 but what settings? I have already followed the manual ( your link was to mach3 and the screens are quite different) to no avail.
Will see how I get on with Modbus RTU
Proximity switches or limit switches
By chillybo in forum Gantry/Router Machines & BuildingReplies: 52Last Post: 29-06-2021, 11:50 AM -
Maplin closing-down sale
By Doddy in forum Classified Ads, Buy, Sell & SwapReplies: 0Last Post: 13-03-2018, 09:13 PM -
Mach4
By D-man in forum Artsoft Mach (3 & 4)Replies: 3Last Post: 18-10-2014, 05:58 PM -
Mach4 in production run G52 offset with Sub
By Lee Roberts in forum Artsoft Mach (3 & 4)Replies: 8Last Post: 25-08-2014, 11:53 PM -
Mach3 vs Mach4
By Saracen in forum Artsoft Mach (3 & 4)Replies: 42Last Post: 15-09-2013, 04:55 PM
